Which of these radeons is better purchase?
Discussion in 'Desktop & Laptop Computers Forum' started by zoolap, Oct 25, 2003.
  1. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    I've got a p2-450 in which i've got an original matrox millenium 2d card. I want to get a better card that I can later move into a p3-933 to make into an htpc. Which is better purchase? Chepare is of course good for me. I want it to have dual output with dvi so that it can in future be used with a projector. Also noise is an important consideration.
    Hercules 3d Prophet 9600SE AGP 8x 128MB DVI-I TV-Out retail Box
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=54474
    or
    Sapphire Radeon 9600 APG x8 128MB DDR DVI-I TV-Out Lite Retail
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=49372
    Thanks.
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    Both of your listed cards will not be pushed in the slightest by your proposed system so just buy the cheapest.
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    well the common opinion is that for an hcpc, radeon is the way to go. However, as Graham says, either one is piles and plenty for you current set up
    ad
  4. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    My guess is that neither will work. Most (perhaps not all) RV350 and RV360-based AIBs are keyed for AGP 4x and 8x operation only. I'd also be suprised if your motherboard supports AGP 2.0; another requirement of these cards.
    MuFu.
  5. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    mufu,
    that's a good point about agp - i'll check if they are agp 2 compatible, worst case I can get the 9600 and put it in the p3 machine which uses an intel 815 chipset which must do 4x.
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    For an HTPC ensure the card you get doesn't have a fan, non-Pro 9600s are usually like this, the brand of card really matters very little indeed.
  7. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
  8. Steve1138
    Steve1138
    I put a 9500 in my new HCP and had to immediately add a ZALMAN heat pipe passive VGA cooler... then as this was still hot I added 2 (60 x 15mm) small PAPST fans on the ZALMAN bracket, over the top...
    Will probably replace this with a 9200 and move the 9600 into my main home PC so I can go totally noiseless in the HCPC (on the VGA at least)
    Steve
