which of these budget compact cameras?
Discussion in 'Photography Forums' started by sswats, Oct 12, 2005.
  1. sswats
    sswats
    Feb 23, 2004
    255
    +9
    I need a point and shoot camera. Small, but provides very good pictures. indoor and outdoor.
    I've narrowed it down to these around the £200 mark. (the casio is overbudget but i just thought I'd include it).
    If you can recommend any others I'd be grateful.
    Fuji F10 v Sony DSC-W7 v Casio EX-Z750 v Canon IXUS 50 v Nikon Coolpix S1
    Fuji F10 £211
    http://www.dpreview.com/reviews/fujifilmf10zoom/page10.asp
    Sony DSC-W7 £206
    http://www.dpreview.com/reviews/sonydscw7/page10.asp
    Casio EX-Z750 £240
    http://www.dpreview.com/reviews/casioz750/page9.asp
    Canon Digital IXUS 50 £215
    http://www.dpreview.com/reviews/canonsd400/page10.asp
    Nikon Coolpix S1 £198
    http://www.dpreview.com/reviews/specs/Nikon/nikon_cps1.asp
    My current choice seems to be the Fuji F10 thanks to the review. but the problem with that is no viewfinder. with my old camera there were a few times I couldn't have taken a picture without a viewfinder so that ruins it for me. also it has XD. currently i have a couple SD cards cos I use them with my PDA as well (sony would be a pain too I suppose).
    there is a replacement for the F10. the F11
    http://whatdigitalcamera.com/news/F...th_extended_creative_controls_news_69047.html
    is it worth waiting for or are the specs pretty much the same (it doesn't realy solve my problems with it). any idea how i find out how much it will cost
  2. T0MAT01
    T0MAT01
    Dec 25, 2004
    2,383
    113
    Devon, Sussex or somewhere inbetween.
    +566
    I'd go with the Canon IXUS 50 myself, I used a mates one recently to take some indoor shots and I was well impressed with it.
    The Fuji is no doubt a good camera too but if you already have SD cards then for me it would be a no-brainer.
  3. sswats
    sswats
    Feb 23, 2004
    255
    +9
    I just went to jessops.
    the Ixus 50 is nice and compact but screen is so small. there is the Ixus 55 but thats an extra £30 i think. and its bigger.
    the casio is gourgeous, but review as you can see aint great.
    Fuji was dull looking. but its the cheapest and the best quality. xD is a shame but its the lack of viewfinder thats stopping me.
    the guy in jessops said you can get hoods that pull out shading the screen so you can shoot in bright sunlight.
    how much are these?
  4. sorbiegunner
    sorbiegunner
    Jan 16, 2004
    184
  5. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
  6. sswats
    sswats
    Feb 23, 2004
    255
    +9
    ok Canon takes the lead I suppose.
    Should I get the Ixus 55?
    can anyone tell me the difference? I know its a bit bigger and it has a nice cool big 2.5" screen.
    is the quality the same?
  7. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
  8. sswats
    sswats
    Feb 23, 2004
    255
    +9
    I've read that the Ixus 50 and 55 have very poor battery lives.
    whilst the Fuji F10 has a brilliant battery life.
    its another factor favouring the Fuji.
  9. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    I've had my Ixus 50 since June and I've charged it three times. I haven't counted how many shots I've taken on each charge but it's in the hundreds. Battery life is excellent. The only slight downside is that there's no battery indication until the battery starts to run low.
  10. sswats
    sswats
    Feb 23, 2004
    255
    +9
    ixus it is then.
    thanks guys.
    I'll probably get the 55 tho as long as its not too much bigger than the 50. I'll check it in the shop. its only an extra £15.
  11. SPRINGERS
    SPRINGERS
    Mar 25, 2005
    434
    43
    Braintree
    +139
    I hope you enjoy the excellent Cannon ixus, for further info regarding cameras try Steves Digicams in the U.S.A. this is the best review site I have found!
  12. sswats
    sswats
    Feb 23, 2004
    255
    +9
    ok I got the ixus 55. I really liked the bigger screen. And Jessops only had £7 difference between them after net price matching (although they couldn't match exactly)
    I would have shopped around more but I'm leaving tomorrow.
    anyway, so far, VERY nice.
    thanks for your help guys. you saved me from getting a Fuji.
  13. Aleem
    Aleem
    Oct 9, 2005
    155
    Stockton-on-Tees
    +8
    I was just about to order the Ixus 55, but I thought it was the same physical size as the 50 :rolleyes:
    According to the canon website the 55 is 86.0 x 53.5 x 21.6 mm and the 50 is 86.0 x 53.0 x 20.7 mm.
    So, 9mm thicker and 5 mm wider.
    The reason I'm not going for the Ixus 750 is because it just doesn 't feel anywhere near as nice as the 50.
    Can anyone tell me if the ixus 50 and 55 'feel' the same in the hand?
  14. sswats
    sswats
    Feb 23, 2004
    255
    +9
    I compared botht the 50 and the 55 in Jessops before I bought.
    to me, the difference was minimal.
    noticeable if you put them side by side but still he 55 is very compact.
    and the big screen is just :thumbsup:
  15. Aleem
    Aleem
    Oct 9, 2005
    155
    Stockton-on-Tees
    +8
    Thanks swwat, will pop into a camera shop to compare them.
  16. Mics49
    Mics49
    Jul 30, 2004
    945
    28
    +58
    i think you're looking at 0.5 and 0.9 mm which should be un-noticable? :)
