Which of these 4?
Discussion in 'Computer Peripherals & Consumables' started by maggo87, Nov 26, 2010.
  1. maggo87
    maggo87
    Dec 14, 2007
    600
    +15
    Hey, how we all doing? im in need of a little advice, i am purchasing a screen in next week and dont know which to chose, the screen is going to be solely used for ps3 and xbox 360, absolutly nothing else, just gaming, so heres the links and which one would be best.
    Iiyama ProLite E2410HDSD 24" Widescreen LCD Monitor - Black []
    Samsung P2450H 24" Widescreen LCD Monitor - Glossy Black [LS24LRZKUV/EN]
    BenQ G2420HDBL 24" Widescreen LED Monitor - Black [9H.L3XLB.QBE]
    IIyama Prolite E2472HD 24" Widescreen LED Monitor - Black [PLE2472HD]
    or any others that you recommend, max £170 and would go smallest 24"
    John
  2. maggo87
    maggo87
    Dec 14, 2007
    600
    +15
    anybody?
  3. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,828
    Norfolk
    +2,517
    Ideally you'd want a 1280x720 screen if this is for console gaming but you won't find it in monitors at the size you want and TVs are likely to extras (like a TV tuner and remote) that push the price up.
    Those four are likely to be much the same.
  4. maggo87
    maggo87
    Dec 14, 2007
    600
    +15
    ok, thanks for the reply
