Which network cable to use?
Discussion in 'Cables & Switches' started by Cheng, Jan 18, 2003.
  1. Cheng
    Cheng
    Dec 19, 2002
    391
    +7
    Do I get smoke-free or normal cat 5. cable for making the FFRT cable (or whatever)?
    Also, does the quality of the cable matter - http://www.videkonline.co.uk/SubSections.asp?sectionID=160
    Would "4 Pair UTP Cable - Solid Core Enhanced (305m) " be ok?
    Also, what would be better, solid core or strands?
    Thanks,
    Cheng.
  2. Cheng
    Cheng
    Dec 19, 2002
    391
    +7
    Anyone?
  3. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    You need solid core cable for this project. As long as you buy Cat5e cable you will be fine. Rather than buy 305m of it though which will probably cost at least £50, BandQ do it in 50 or 100 metre rolls for reasonable prices.
  4. wandgrudd
    wandgrudd
    Dec 16, 2002
    184
    Nottinghamshire
    +7
    wrong it will cost abot £30 for 305m of cable you can get it from here
    wandgrudd
  5. Cheng
    Cheng
    Dec 19, 2002
    391
    +7
    I love you!
    But....isn't this cable on the cheap side, on is all cat 5e equal?
  6. wandgrudd
    wandgrudd
    Dec 16, 2002
    184
    Nottinghamshire
    +7
    i thinks its all the same
    any way this is what i used for my system (computer and home cinema) and it seems fine .
  7. Cheng
    Cheng
    Dec 19, 2002
    391
    +7
    What about low smoke cables, are they better?
  8. wandgrudd
    wandgrudd
    Dec 16, 2002
    184
    Nottinghamshire
    +7
    cant say never used any.
  9. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    Yeah, if you're planning to set light to it.
    But seriously, all Cat5 has to conform to certain specifications so it should all be equal. The only differences are the materials used in the sheathing, which will make no difference.
    The stuff in the link posted by wandgrudd is a well known make in the networking world and should give good results.
  10. RichB14
    RichB14
    Nov 8, 2002
    788
    Surrey
    +19
    What are you using the cable for ?
  11. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
