Which MP3 media player should I choose ?
Discussion in 'Music Streamers' started by Andrew Dade, Jan 18, 2008.
  1. Andrew Dade
    Andrew Dade
    Aug 27, 2005
    178
    Norfolk, UK
    +6
    Hi Guys,
    Probably like most of you I have numerous USB discs and HDD's full of MP3's. I have a couple of Roku soundbridges and I would like to find something similar that has :
    USB connection for portable HDD and memory sticks, auto detection of directories etc, playlists maybe
    Optical digital out
    Analog Audio L/R
    Reasonable quality.....
    Small size
    Ethernet not so important...
    Any suggestions ?:)
    And thanks in advance
  2. Autopilot
    Autopilot
    Feb 5, 2005
    7,607
    Region 2
    +1,497
    It's rare for an MP3 player or streamer to have USB external drive support for a number of reasons, your best bet is to look into NAS's - which would work with your Roku's too.
  3. Andrew Dade
    Andrew Dade
    Aug 27, 2005
    178
    Norfolk, UK
    +6
    Thanks for the reply, I have a NAS (QNAP) which works well. The reason for the request is convenience, I have USB in the car and would be very convenient to bring the stick indoors and plug in, there are a few low quality boom boxes out there with USB but nothing half reasonable...
  4. daverb
    daverb
    Jan 27, 2005
    13
    3
    have you looked at the TEAC CR-H255?
    Fulfills some of your criteria. It's basically a micro Hifi with a USB port so you can connect external HD or MP3 player...
  5. Andrew Dade
    Andrew Dade
    Aug 27, 2005
    178
    Norfolk, UK
    +6
    Thanks for the suggestion looks nice. Do you have one ?
    If so how is the id3 tag support / display ?
    Have you had any issues with recognising USB discs ?
    Thanks in advance:thumbsup:
