Which mount for an LG 42PC1D
Albie
Am trying to find what is the best mount to get for the LG 42PC1D. Is it worth getting a flush fit, or one with a swing arm. Not sure I would use the swing arm for viewing, but does it make it easier to connect the cables.
Any suggestions, recommendations and pictures would be great.
mannyo
I have mine mounted on the wall with an Omnimount Fixed universal bracket from Currys. The TV sets a few inches from the wall. Plenty of room behind for ventilation as the PC1D has no fans. I attached the cables to the back of the screen first, then lifted it onto the bracket as once mounted you will need to fumble around with the connectors to get them in.
