Which model is better for a budget TV
ImmortalDuckyy
so I’ve decided on getting either the lg 43un73006LC or the LG 43UN81006LB but dont know which one to buy. The specs look the same to me but the first TV is about £30 cheaper.
I am basically looking for a budget 4K TV for my bedroom to replace a 720p LG tv from 2010. Any similar alternatives would be appreciated, my budget is up to £400
Dodgexander
Anything in the same range can more or less be considered the same TV. In this instance the UN8100 may have different aesthetics, but the addition of an extra HDMI port is the standout difference. Picture quality between them will be the same.
See the spec sheet below to notice differences:
If you are looking for alternatives I have a best buy guide here:
Most people wouldn't choose a TV using an IPS panel for a bedroom TV unless they need good viewing angles.
LG SP11RA Soundbar Review Coming Soon to AVForums
