Which mobo for HTPC (must have S3(STR) capability)?
Discussion in 'Home Entertainment Computers' started by spudgun01, Apr 18, 2007.
  1. spudgun01
    spudgun01
    May 26, 2005
    114
    19
    Hi all,
    Following advice and help from this forum I purchased a ECS P4M800PRO-M (V2.0) mobo for a HTPC project I was tinkering with. Nice mobo; supports my Intel Core 2 Duo E6300 and seems stable!
    However I've just found out from ECS that this mobo does not support full S3(STR) standby:eek:!!
    I want to put my system into full standby (fans off) with my MCE remote!
    Can anyone recommend a mobo that supports S3(STR) with Intel Core 2 Duo E6300 support and an AGP slot for my Radeon 16500 AGP gfx card? (oh it has to be microATX to fit in the Antec Fusion case I'm thinking of getting!!!)
    To be honest - I could at a stretch do without the AGP slot if it makes things easier:D.
  2. craigd
    craigd
    Nov 29, 2006
    912
    46
    +130
    You may want to look at SpeedFan - a free piece of software that allows you to change fan speed based on temperature of CPU, northbridge, etc. May save you shelling out on a new mobo.
  3. spudgun01
    spudgun01
    May 26, 2005
    114
    19
    Craigd - thanks for the reply.
    Just to clarify; it's the PSU fan that doesn't switch off in standby as the P4M800PRO-M (V2.0) doesn't have full suspend to RAM function (unlike my laptop!) and so in stand-by the PSU fan still keeps a hummin'!!
    Will/could SpeedFan cure this?
    If not - anyone else can help with new mobo??
  4. spudgun01
    spudgun01
    May 26, 2005
    114
    19
  5. craigd
    craigd
    Nov 29, 2006
    912
    46
    +130
    Only if mobo and PSU support it - I bought a fanless PSU which is great if you PC is lower power consumption (I have a laptop CPU, 2 HDDS, 2 PCI tuners, 1 DVD rom and use on board graphics). It was about £90
  6. spudgun01
    spudgun01
    May 26, 2005
    114
    19
    Hi -sorry to belabour (is that the word?) the point, but has anyone got any ideas on a decent mobo that is mATX and has full S3 (Suspend to RAM) function - it must support Intel Core 2 Duo E6300???
    What Intel Core 2 Duo supported mAXT mobo is everyone else using????
    Many thanks -
  7. jon_c0
    jon_c0
    Dec 4, 2005
    1,078
    48
    +85
    I'd expect not supporting S3 fully is the exception rather than the rule... I'm using an Intel DG965OT. Not the cheapest board by a stretch, and not very versatile for overclockers. However...it does include onboard X3000 graphics to which you can add DVI to the standard VGA via an ~£8 ADD2 card. Stable and, as you'd expect from Intel, frequent BIOS updates. Oh...supports suspend/wake from S3 properly along with Intel Quick Resume (although I find the later pretty pointless). Quite a popular board amongst HTPC builders, although I suspect that there's more functionality about for less now.
  8. spudgun01
    spudgun01
    May 26, 2005
    114
    19
    jon_c0, Thanks for the heads-up!
    This certainly looks like a good mobo & would fulfill my needs - unfortunately Dabs.com is out of stock!!!
  9. spudgun01
    spudgun01
    May 26, 2005
    114
    19
    Sorry to be a pain - I've found one on Amazon a a good price & wanted to check - when you say supports S3 (STR) properly, do you mean that when entering standby everything is off, including PSU fans? If so, gonna get one!!!
  10. jon_c0
    jon_c0
    Dec 4, 2005
    1,078
    48
    +85
    Yep, that's what S3 is :) . Visibly and audibly everything is off, hard disk, all fans etc case+motherboard - a true standy/STR that can be awoken by keyboard/mouse/remote (providing you use this patch in XP, if they are USB, but that seems pretty common). I'm reasonably sure most recent motherboards are now pretty reliable in this respect...sounds like you might have been unlucky with your original one.
  11. spudgun01
    spudgun01
    May 26, 2005
    114
    19
    jon_c0, many thanks for your help!
  12. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    I was thinking about a Intel DG965OT... In an Antek Fusion case.
    Can anyone recomend a good (queit) heatsink for a E6660?
    Sean.
  13. jon_c0
    jon_c0
    Dec 4, 2005
    1,078
    48
    +85
    To be honest, I can hardly hear the heatsink and fan that came with my retail pack E6400. If your E6660 comes with one too, I'd give it a spin (pun intended) first...
  14. tim_kay
    tim_kay
    There are problems with S3 in Vista though, so be warned!
    Good heatsink, lotsa options, all the Zalman high-end very good, fair bit of room, but again not really needed in the antec case, stock heatsink on c2d run cool and quiet, what they were designed to be!
  15. jon_c0
    jon_c0
    Dec 4, 2005
    1,078
    48
    +85
    Oh, good point, sorry! Not wishing to be misleading I probably ought to have made it clear that my positive S3 sleep/wake experiences are with XP MCE, and I haven't any experience of Vista.
