Which make is best for buying second hand sky+ box ?
Discussion in 'Sky Digital TV Forum' started by JamieBee, Jul 10, 2010.
  1. JamieBee
    JamieBee
    Jun 28, 2005
    942
    Ashford, Kent
    +10
    I have had an Amstrad off ebay with clicking and grinding noises coming from the drive and now a Pace that the hard drive has failed on it 2 weeks after I bought it.
    Are some Amstrads ok and I just got unlucky ? Are Paces usually ok ? Thomsons ?
    I now have to buy a third one and really want to make sure it is the last :(
  2. Oily
    Oily
    Jun 11, 2007
    1,049
    Radcliffe
    +83
  3. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,448
    Oxford
    +1,302
    If only the HDD has failed on the Pace box why don't you replace it - a fairly simple job. Pace boxes are considered the most reliable box BUT all boxes have HDD which are usually the most unreliable part of all of them.
  4. JamieBee
    JamieBee
    Jun 28, 2005
    942
    Ashford, Kent
    +10
    Because I have not a clue how to do or the cost of another HD. If a new box is about £15, I will buy another as I cannot be bothered with the hassle.
  5. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,954
    Greek Island
    +507
    Typical HDD life is 3 years so, as long as you keep buying old Digiboxes with old HDDs, you'll have hassle. Replace a HDD and you'll have a better chance of getting 3 years trouble-free recording. If you can't replace it, get a mate to do it.
  6. JamieBee
    JamieBee
    Jun 28, 2005
    942
    Ashford, Kent
    +10
  7. FoyleFlyer
    FoyleFlyer
    Oct 25, 2008
    41
    11
    Derry
    Try your local Re-Cycle site. I have just given my Sky+ box away to a very thankful family - see foylefreegle : foylefreegle
    You never know your luck
  8. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,954
    Greek Island
    +507
