Which lower cost sub to look at??
Discussion in 'Subwoofers' started by Mathew J, Jan 18, 2005.
  1. Mathew J
    Mathew J
    Considering either of the following...
    Athena Technologies Audition Series 400w Sub AS-P400
    Klipsch Synergy Series 225w Subwoofer KSW-10
    JBL Northridge 250W Subwoofer E150P
    Velodyne VRP 1000
    Or should I just save my pennies for either an HSU or SVS??? thanks
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Unfortunately none of those manufacturers have a high profile in UK except Velodyne but the VRP 1000 isn't on sale over here so you will be unlikely to get any opinions on it.
    I have the SVS PB-10 which at $429 is only marginally more than the Klipsch and I can highly recommend it
  3. Mathew J
    Mathew J
    Thanks Ian,
    Any input on the Canton Movie Series speakers?? I was also just considering this route...thanks
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    No input on the Cantons from me personally as I haven't heard them but they do seem to be very popular with forum members.
  5. oldschoolsystem
    oldschoolsystem
    i have a velodyne vrp 1000...i just got it a few days ago..and it works really well...if u have bigger speakers its better because if u turn up the hz it can sound bad.i think mine is at about 70 or 80 and it works really well there.
