which LOW budget speaker package?
Discussion in 'Home Cinema Speakers' started by l0nz, Jun 17, 2003.
  1. l0nz
    l0nz
    Hello one and all
    I'm in need of buying advice regarding a low budget speaker package. I can't afford most of the speakers that people rave about on this forum, but anything will be an upgrade on my current set of home-made mdf bodge jobs. I have a sub already that I'm happy with, a nifty passive-radiator design in oak I managed to fluke just right, unlike the sats. So, looking around the sub-£200 for a 5 speaker set with preferably floor standing fronts, it looks like my only options are Gale, Pioneer or Eltax. Can anyone give me UNBIASED opinions on these brands, yes I know they are like the Skoda of the speaker world, but do they really sound that bad? I can always peel the badges off ;)
    Please, no replies saying "save up for this and that" cos any savings I have will be used for more urgent things, like paying off my big fat mortgage. I have to stick to this low budget.
    Thanks muchly in advance.
    L0nz
    PS the speakers will be driven by a Yamaha RX-V590 prologic amp but this is next in line to be replaced, so it's not much of a factor.
  2. gingerone
    gingerone
    Dec 10, 2002
    2,414
    +302
    I have just replaced a pioneer sat/sub package that I had for about 2 years for kef eggs mark 2 and the difference is shocking.
    The pioneers were very cold and hard sounding.
  3. BigAde
    BigAde
    Jul 22, 2002
    964
    East Sussex
    +23
    You're right that you won't get much choice in that price range. Keep an eye out for second-hand kit in the classifieds of this forum and in your local papers. As long as you test them before buying, you should be fairly safe - there's not much to go wrong in speakers.
  4. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Try www.petertyson.co.uk and have a look at their Tannoy av speaker package for £200 MX2s, MX1s & MXc pretty good - not floorstander but better quality than the other stuff you've mentioned. I used to have 4 mx1s & 1 mxc and it was a pretty good setup
  5. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Richer Sounds have a selection of budget speakers including older models from the KEF and Mission range that may well suit you
  6. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    M72 Cinema package from Hyperfi.co.uk might be worth a look at £200. Bookshelf fronts though.
    MuFu.
  7. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    How about the Wharfedale Diamond Screen3 package. 8.3 Floorstanders (Fronts) 8.1's for Rear Plus Centre. About £260 from QED. What HiFi 5 Star Package
  8. jdanielp
    jdanielp
    Jun 20, 2002
    176
    Edinburgh
    +3
    i was about to suggest the same if you can budget up a bit. i have the Screen3 package and it is excellent (although i will probably upgrade to the new DFS-18 bi-polar rear speakers at some point for an enhanced cinematic rear sound field. the 8.1s are fine as rears though and are great for multi-channel music).
