Which Logitech Harmony for Thomson DHD4000?
Discussion in 'Home Cinema Control & Remote Controls' started by gareth71, Dec 23, 2006.
  1. gareth71
    gareth71
    Oct 5, 2006
    13
    Which member of the Logitech Harmony range gives best results (user-friendliness, easiest access to functions, maxiumum compatibility, etc.) for use with a Thomson DHD4000 freeview PVR? This PVR makes fairly extensive use of the five coloured buttons on the remote handset, and most universal remotes only seem to have four of these coloured buttons ...
  2. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    All Harmony remotes are functionally the same, with the possible exception of the 1000 series.
    As you go up the model range (higher numbers), you get more features, such as colour screen, rechargeable battery, more programmable keys, etc.
    Choose the one that has the features and design that you want.
