Which LNB?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Panavision, Feb 10, 2003.
  1. Panavision
    Panavision
    Mar 12, 2001
    538
    +15
    Been reading a few threads, Cambrige LNB seems to be a problematic LNB...? I'm looking to buy a new one 'cos my receiver is having problems picking up some Vertical channels, mostly between 800 - 900 channels.
    Dish alignment is correct.
    Receiver is Panasonic TU-DSB30
    Anyone know of a decent supplier? Exactly which LNB should I buy?
  2. Fernsehman
    Fernsehman
    Erm, if you have a Sky "minidish" your choice will be limited to the LNB it was designed for. If that was "Cambridge" then that may be your only choice.
    I've seen lots of LNBs on the satcure.com site but you'll have to decide what you want. There have been some batch problems with "Cambridge" LNBs (manufactured now by Channel Master I believe) so maybe you should buy a new dish and LNB - how about a 60cm dish to minimise "drop-out" in bad weather?
    Fman
