Which LNB?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by barney11, Jan 9, 2005.
  1. barney11
    barney11
    Dec 10, 2004
    I am going to fit Sky+ myself, which make of quad LNB would you recomend and how easy are they to fit?
    Dave
  2. KingOfGondor
    KingOfGondor
    Dec 30, 2004
    558
    28
    +25
    i'm thinking about doing this too.
    two reasons really
    1. get the exact box i want
    2. cable goes exactly where i want it.
    my question is... if i book an installation, can i just ask for them to check my installation, fit an LNB and my subscription card?
    as the installation should be free, this stuff shouldn't cost anything, right?
  3. barney11
    barney11
    Dec 10, 2004
    I don't think it works like that,you only get free installation because you are buying there equipment.
    Dave
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Too right it doesn't work like that. Free installation only if you get the kit from Sky and agree to have it connected to the phone line for 12 months.
  5. KingOfGondor
    KingOfGondor
    Dec 30, 2004
    558
    28
    +25
    i see. ok thankyou. so i have two options that are mutually exclusive....
    1. fit entire setup myself and call them to send me a card and activate (my dad has sky downstairs i'm just adding sky+ with multiroom)
    2 let them do it all
  6. barney11
    barney11
    Dec 10, 2004
    Recomendations on which Quad LNB still needed and how easy are they to fit :lease: .
    Dave
  7. bilsat
    bilsat
    Jan 10, 2005
    2
    Hi there.
    When choosing a LNB make sure that the LNB you use is disigned for the dish you have.If it is a Sky dish DO NOT use a LNB designed for a standard dish as the ilumination of the dish will be incorrect and the results willl be poor quality signals, weak signals from the two outside feeds etc...Pete
