Which lens, sigma or canon
Discussion in 'Photography Forums' started by mattym, Apr 4, 2005.
  1. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    ive asked this question on my own forums and on a couple of others but opinion is split,
    i hae a 300d and want a 70 - 300mm lens, i dont have a good budget, so im looking at £150 max, so, sigma 70-300 APO super macro II or canon 70-300 USM
    Im lead to beleive the canon is soft between 200 - 300
    Opinions welcome! :)
  2. bazzason
    bazzason
    i too am looking for a lens in this range, but for a D70, so would be interested in replies on the sigma lens (its one of the ones i am looking at).
    from what i have read (i have heard similar things about the comparable nikkor lens), the softness at max zoom seems to depend on what lens you are comparing it to. some people say its of a reasonably good quality, some say it could be better. i think the overriding view is that its pretty darn good for the price, whichever way you look at it.
    i have seen some pics taken with a similar budget lens on the dpreview website, and they look pretty good to me (i am new to this game, though ;))
  3. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    i think the nikkor lens on the D70 is a good lens, supposed to be better than the kit lens on the 300d..
    I have heard that sigma suffer from quality issues, and the ones that are available for about £140 on the net are grey imports(for the canon anyway)and so may not be of the best quality...
  4. Johndm
    Johndm
    Jan 25, 2003
    1,819
    Bedford UK
    +66
    Well I've been using the Canon 75-300 for just under a year, and had some fair to good results with it.
    Yes it can be a bit soft at 300, but nothing that Photoshop can fix, unless its a very poor shot to start with.
    However, I wanted better quality, and after much reading and thought, decided to go for the Canon 100-400 L series. Now this lens costs a tad more than the 75-300 as you probably know, but the results are far superior.
    So, if you think you will be happy with the 'prosumer' grade 75-300, it can achieve good results.
    If you think you will need better quality later, save your dosh for the L series, any maybe get a second hand cheapy to tide you over for now.
    Have a look here..
    http://www.airliners.net/search/pho...rnet.com&sort_order=views&distinct_entry=true
    Everything taken in 2004 in the air was with the 75-300
  5. bazzason
    bazzason
    don't get me wrong, the kit lens 18-70mm is wonderful, but i want something that will go from this range to around 300mm. hence i'm looking at the options. my (perhaps illogical) thinking is the difference between a £150 lens and a £300 lens of the same focal range would get me a days training course with a Nikon instructor. given my relative newbie status to DSLRs, this has to be the smart option, no?
  6. Radiohead
    Radiohead
    Dec 24, 2001
    4,337
    Amazingstoke
    +431
    I just plumped for a 70-300mm G lens for my D70 and it was just £80 after Jessops did a price-match. For that money you can't go wrong and it's seems a very decent lens for the money.
    I'm new to this as well and guessed (correctly it seems) it would be sufficient for me for now, and cheap enough to experiment with. Should I want to get a better lens in time then I haven't made a massive investment now. Several others here also have the 70-300 G lens (rather than the £250 ED version) and are also seeing good results.
  7. Johndm
    Johndm
    Jan 25, 2003
    1,819
    Bedford UK
    +66
    Now as I'm a Canon guy, I can't really comment on a 'Nikon G Lens', but £80....come on. :suicide: On a near Pro quality body....
    I mean......my Pro UV filter that cost nearly that...
    Good glass costs money, like good HI FI, and this lens must be like hanging Alba speakers on a SONY TA-DA9000 ES amp.
  8. bazzason
    bazzason
    but isn't is also true that every now and again, you can stumble across an exception to the rule? a bargain, if you will? ;)
  9. Radiohead
    Radiohead
    Dec 24, 2001
    4,337
    Amazingstoke
    +431
    Remember it's actually a £170 lens that just got well price-matched. A local store had a second-hand one for £90 on the same day.
    As for the quality - it might surprise you. I'm happy with it. Who knows, in a year's time I might demand more from a lens and can upgrade then, but I couldn;t justify spending £500 on a lens right now. I don't envisage using telephoto a huge amount but wanted one in my bag for the times when I do. Macro and portrait floats my boat which is why I'm shortly buying a Tamron 90mm macro lens for £300 and a Nikkor f/1.8D 50mm prime. Those, along with the very nice 18-70 kit lens, and the decent 70-300 gives me coverage for most of the situations I'll be in.
    Horses for courses.....
  10. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    thanks for the imput guys
    on the subject of bargain lenses, the canon 50mm F1.8 seems to be a very capable lens for a mkII plastic body!
  11. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
    Or perhaps like hanging a £70 50mm mk II off a £2000 1D? :smashin:
    I've not seen the Nikon lens in action, but reports of it seem too indicate it is another one of those killer bargain lenses!
    Shame it's not in Canon fit for you! I believe the OLD Sigma 70-300 was fairly decent, but the new one is apparantly not as sharp (although clearly neither are super duper sharp)
  12. Johndm
    Johndm
    Jan 25, 2003
    1,819
    Bedford UK
    +66
    Near 'L' quality there....a well respected little lens... :hiya:
  13. Johndm
    Johndm
    Jan 25, 2003
    1,819
    Bedford UK
    +66
    The 50mm looks MUCH better with its proper lens hood...hard to find though, and a tad expensive.. :D
  14. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    is there any other lens i should consider in the <£200 bracket?
  15. condyk
    condyk
    Jul 12, 2003
    399
    Jewellery Quarter, Birmingham
    +7
    It's funny but I was asking the same question a month or so back and decided on the Sigma APO 70-300 Super II. It's a very, very good lens for the money but, as with all the competition I looked at for Canon 300D (and I REALLY looked hard, convassed views via different fora and read every review!!) it is not capable of producing as sharp images when compared directly to the expensive competition. Why should these cheaper lenses do that anyway? It's great value and does a really good job in that niche :) The Macro on it is pretty darn good too. I'm pretty fussy and I think you'll like it.
    So, my view is that it's the best option just now and only the Canon 100-300 USM is worth considering as an alternative, but that very expensive in UK for what it does. I would still go for the Sigma even if pricing was closer! Build quality is very good, as with the other Sigma's I've had, and resale is good. The Canon 75-300 USM doesn't seem to be well liked, though there may be some particularly good ones around too, if you're lucky enough to find one! Again, decent resale.
    However, having been happy with the Sigma it will soon be going as I have just bought a 70-200 F4 L, simply because it was offered MINT/boxed at a price I just couldn't refuse (I tried!!) I really didn't intend upgrading for another six months as the Sigma has met my expectation as a 'learning zoom'.
    When I spot a bargain 50mm Canon then I will get that too. I am led to believe the mark 1 is a tad better than the mark II, but others here may have a direct user view that's different. I am only going on what I have read!
    Long term, before my next big Africa trip, I will get a big zoom too. Whichever is the best price/performance/handle-able at the time. Along with a nice macro lens I think that will do me, as my main interest is nature shots.
    PS make sure you get the Sigma APO and not the cheaper version. The APO Super II version also has much better resale that the original Super. You'll lose little cash, if anything, if you get a nice second hand one and sell it again later.
  16. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    thanks!
  17. Oakey
    Oakey
    Aug 4, 2002
    536
    +6
    How do you tell the difference between the original Sigma and the Super II? I ask as I picked up a Sigma 70-300 2nd hand for about £70 a few months ago. I was worried that it was the original but I've checked on www.warehouseexpress.com and there is:
    70-300mm F4-5.6 DL Macro Super
    [​IMG]
    and
    70-300mm F4-5.6 APO Macro II Super
    [​IMG]
    Mine looks like the second one but neither mine or the one in the picture say Super II (and I believe the original wasn't APO)?
  18. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    the apo is a superior lens apparently! dont really know much more than that
  19. condyk
    condyk
    Jul 12, 2003
    399
    +7
    There is no obvious indication on the barrel, but I guess you could quote the serial no. to Sigma and they will tell you. They've been quite prompt when I've asked them questions in the past. My Super II APO had a red ring around the top of the barrel, if that helps!? Don't THINK the cheaper one has that.
    The instruction book has Super II written on it, of course, but that's no guarentee you have a Super II lens unless bought new I guess! Ditto the box.
    The APO II is a very decent lens. I have sold mine now and lost just £1.50 on the deal :clap: over what I paid for it, so very happy. Can't go wrong with these lenses if you buy carefully.
    Mattym, did bidding go too high, or did you fancy something else?
  20. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    no i missed it, i was working! Got a New one ordered though, so not a problem!
  21. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    Got my sigma 70-300 apo super macro II, i need a bigger kit bag!
  22. DJW
    DJW
    Aug 29, 2002
    965
    16
    What price did you pay in the end & from where please ? Might be tempted ;)
  23. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    i got it from Microglobe, they delivered it next day special delivery, as soon as i remembered the auction and realised i missed it i rang them. £139 + £7 for delivery
  24. condyk
    condyk
    Jul 12, 2003
    399
    +7
    As far as I know that's the best price around at the moment for new in stock item. I checked before I ebayed mine.
  25. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    there is some debate that it might be a grey import, but it has a warrenty card in english with it, so im not really bothered. Also preliminary wobbly shots suggest that if i can keep the damn camera still it is quiet sharp at the 300mm end!
  26. condyk
    condyk
    Jul 12, 2003
    399
    +7
    Yes, I agree with you about the whole shake, rattle and roll thing, but you can still see it's a good lens for the price ... even better had you got mine for £100 :rotfl: :rotfl: :rotfl: Just joking!
    It's cash and more cash, eh? First lenses, then bigger bag, then a tripod or monopod.
  27. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    well i got a bigger bag and a tripod but i think i will invest in a bean bag for resting the lens on stuff...
