Which LEAD to record from VHS to E95 ?.
Discussion in 'Blu-ray & DVD Players & Recorders' started by luckylewis, Feb 1, 2005.
  1. luckylewis
    luckylewis
    Jan 14, 2005
    157
    19
    Oxford
    Which lead (as in name) do I need to connect my E95 to my VHS so that I can record and archive my tapes please and also what sort of good quality makes are around :lease:
  2. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    Any half decent Composite Scart to Phono should do.
    I would go for one that has six phonos (video & audio L, R in and out), that way yo would be able to record both ways.
    You don't need to go overboard with composite leads as far as price is concerned.
  3. luckylewis
    luckylewis
    Jan 14, 2005
    157
    19
    Oxford
    Many thanks Kevo :thumbsup:
    Malc
  4. whatdoiknow
    whatdoiknow
    Don't know if you live near a Boyes ( I think there more likely found around here up north but I just bought some scart to phono cables either 1.6 or 3 metres and they must be made by the same company that built the proverbial toilet (brick s'house) as they are thicker than any others I've seen and have excellent scart and phono connectors and they only cost £4.95 each.
  5. luckylewis
    luckylewis
    Jan 14, 2005
    157
    19
    Oxford
    Thanks and have just done a search on the web and the closest is 100 miles away in Nottingham. :(
    Malc
  6. Nelviticus
    Nelviticus
    Jun 21, 2003
    468
    Hitchin
    +68
    Why use a Scart to Phono? The E95 has Scart sockets and so do most VCRs so a Scart to Scart lead would do the job and would probably be cheaper.
  7. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    Because it would be wasted on a VCR as it's primary use is for a SCART RGB signal in (from a STB) and RGB out to the TV.
