which lead for barco 701 iscan pro
Discussion in 'Projectors, Screens & Video Processors' started by patt, Jan 16, 2005.
  1. patt
    patt
    Nov 18, 2004
    394
    huntingdon
    +10
    HI can someone help me i have i Iscan pro and barco 701 which lead do i need to connect them barco it has R G B S V BNC thanks
  2. patt
    patt
    Nov 18, 2004
    394
    huntingdon
    +10
  3. supersub
    supersub
    Mar 14, 2004
    34
    Lincoln
    hi, i've got an i scan pro and barco data 801 s, it's connected with a vga - 5 bnc breakout cable (on e bay), i had to set up the jumpers in the i scan to give sync on green, make sure you get a good connection through any in line connectors, if you don't you will get a white smearing effect especialy on screen titles.
  4. vexorg
    vexorg
    Dec 11, 2002
    268
    16
    Dublin.
    Patt
    Assuming the iscan pro is similar to a duece sdq scaler and you are using the vga out on the iscan via a vga to 5 bnc cable connect the red green and blue cables to the r g b ports and using a bnc Y adapter connect both the H and V cables to the Y end of the adapter and then attach the adapter to the s port. This is how I had it setup on my 701s for testing, but went back to HTPC as it produces a better image.
    Hope that helps.
    Vex.
  5. patt
    patt
    Nov 18, 2004
    394
    huntingdon
    +10
    thanks for that
