HP DV6-2010sa 15.6" widescreen laptop
Operating system Genuine Windows (R) 7 Home Premium
Processor Type AMD Athlon II Dual Core M320
Processor speed 2.1 Ghz The higher the number of Megahertz (MHZ) the faster the processor should be
Memory Size 3GB MB
Memory Type DDR3
Hard Drive Capacity 250 GB The bigger the capacity the more you can store
Optical Drives Lightscribe Super Multi DVD-RW
Floppy Disk Drive NO Floppy disks are 3.5" square and store a small amount of data. CDs,DVDs and memory sticks are now usually used instead
Screen Size/Type 15.6 Diagonal HD Brightview
Graphics Card Type ATI Radeon HD 3200 To enable images to be displayed on your monitor
Graphics Memory up to 1470 MB The higher the memory the better quality images you are display
TV-out YES Allowing you to plug your laptop into a TV to watch DVDs
Sound Type Altec Lansing integrated speak To enable you to have sound from your computer which is great for games, movies and music
Modem Type 10/100/100 gigabit Ethernet Enabling communication with others via the telephone line. A modem is used for the Internet, e-mail and faxing
Wireless Enabled YES Allows you to connect to an existing wireless network such as in a office or a wireless hot spot
No. of USB Connections 4 The more connections the computer has the more equipment you can connect to your computer e.g. a modem, printer, scanner, digital camera, PDA
No. of Firewire Connections 0 High speed data transfer link for digital video and other media. Ideal for quickly downloading video images from a camcorder to PC
Infrared Port Included NO Allowing you to connect to other devices with infrared such as an infrared enabled mobile phone
Other Interfaces 5in1 integrated digital media
Battery Type 6 cell li-On
Battery life (up to) 4.25 hours
Software Titles Included Works, Office H&S Trial
Weight 2.88 kg This is the weight of the appliance in KG
Height 4.2 mm
Width 38 mm
Depth 26 mm
Colour Black
or
Dell Inspiron 1545 Laptop
Processor Type Intel Pentium Dual-Core processor T4300
Processor speed (2.10Ghz, 800Mhz, 1MB Cache) The higher the number of Megahertz (MHZ) the faster the processor should be
Memory Size 3GB MB
Memory Type ddr2 800 mhz
Optical Drives DVD/RW
Graphics Card Type Intel 4 Series Integrated To enable images to be displayed on your monitor
Graphics Memory Shared Memory MB The higher the memory the better quality images you are display
TV-out NO Allowing you to plug your laptop into a TV to watch DVDs
Sound Type 2 Integrated To enable you to have sound from your computer which is great for games, movies and music
No. of USB Connections 3 The more connections the computer has the more equipment you can connect to your computer e.g. a modem, printer, scanner, digital camera, PDA
Other Interfaces Card reader, VGA
Battery Type 4 cell
Battery life (up to) 2 hours
Weight 2.64 kg This is the weight of the appliance in KG
Width 374 mm
Colour black
Will it play football manager 2010 also and is there any laptop out there better than the 2 listed for around 450 pounds?
Memory Size 3GB MB
Memory Type DDR3
Height 4.2 mm
Width 38 mm
Depth 26 mm
Colour Black
or
Memory Size 3GB MB
Battery Type 4 cell
Width 374 mm
Colour black
