Which KEF TDM's for centre backs
Discussion in 'Home Cinema Speakers' started by Too Tall, Jun 25, 2002.
  1. Too Tall
    Too Tall
    May 20, 2002
    541
    Milton Keynes
    +9
    I'm in the process of upgrading my HC to THX.
    I've just bought a Denon A1SR, and am in the process of getting the Kef TDM speakers.
    My first thought was to go for 4XTDM34DS's but a number of threads in the forum have said that using these di-poles as backs is not a good idea as you can not be sat in the null point of both speakers.
    So now I'm confused. Would I be better off using a pair of TDM23F as backs instead?
    I know that a lot of people say di-pole Vs direct raditors for backs is a matter of taste, but I can't find a shop that can set up both set ups for me to see which I like best.
    Any thoughts? Has anyone done this? Am I being silly and should I just go with the 4X34DS's which a number of people swear by?
    Thanks for reading my waffle, I hope someone can help.
    Cheers,
    Too Tall.
  2. Jase
    Jase
    Mar 16, 2001
    10,819
    United Kingdom
    +2,695
    You could use the TDM fronts as surround backs as long as you´ve got the space needed, as you´ll know they´re pretty big.
    Might be worth considering other speakers in the Kef range, something like a pair of RDM 1´s, whilst not an exact match they should do nicely and are smaller. I use a pair of Q85´s as space is limited and they work pretty well.
    I can only suggest experimenting with the different speakers (if possible!!) to see which suits you best.
    cheers
