Which JVC home cinema system?
Discussion in 'Home Cinema Buying & Building' started by Frazal666, Dec 29, 2004.
  1. Frazal666
    Frazal666
    Hi, thanks for reading. I need help choosing between 2 JVC DVD Home cinema systems. The JVC TH-A75 & JVC TH-S8. JVC-A75 is £215 and the TH-S8 is £225. I dont know which one is better, and I cant find any reviews for either of them on the net. If this helps, I am going to use it mostly to play games,watch TV and listen to music, although occaisonally DVD's, so I need a good all rounder. Please help if you have either of these, or if you can suggest a better system for £250ish. (With Optical in). Thanks in advance, and please, any info, I will really appriciate.
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,432
    7
    167
    Birmingham, UK
    +10,137
    I have edited the title of your thread.
    Please use relevant thread titles. Pleading for help because you are 14 is not really appropriate. Your age has nothing to do with it.
  3. Frazal666
    Frazal666
    :oops: Sorry, I'll make sure that doesnt happen again.
