Which ISP for infrequent offpeak usage
Discussion in 'Desktop & Laptop Computers Forum' started by calscot, Sep 25, 2003.
  1. calscot
    calscot
    Oct 29, 2002
    664
    16
    Milton Keynes
    What's the best and/or cheapest ISP deal for surfing the net during off peak times, say a couple of hours a week?
    Cheers,
    Cal.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,320
    Somewhere in South Yorkshire
    +5,675
    I'd say any of the pay-as-you-go offerings (0845 call charges - see your phone provider for details). Before I went broadband, I found the most reliable/robust connection was
    http://www.go2000.co.uk/
    although there is absolutely NO reason why you shouldn't register for several PAYG services, and switch between them if and when one lets you down.
  3. calscot
    calscot
    Oct 29, 2002
    664
    16
    Milton Keynes
    Thanks, Nigel.
    I'll give it a go and see how the bills turn out. If the bills get a bit steep I can always switch to a monthly offpeak deal.
    Cheers,
    Cal.
  4. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    I see from your location you are in an NTL area. They have a 1p per min dial up which would cost you a fiver a month if you used only 2 hours per week, or:
    £10 per month for unlimited dial -up use
    or
    broadband from £17.99 per month.
    (I have used 600Mb/s for the last 3 years @ £19.99 per month)
    Believe me, once you are permanently connected, your surfing habits change forever, and even the thought of dial-up is intolerable.
  5. phenom2003
    phenom2003
    According to computer buyer (who have an isp buyers guide for both dialup and broadband every issue) Clara.net give 12 hours of off peak usage for £3.33 a month. Got pop into a newsagents or whatever and have a look at the guide.
  6. garbon
    garbon
    I use supanet classic which is standard dail up 0845 number.
    very good service with 44000 connction most of the time
  7. LV426
    LV426
    Jul 14, 2000
    13,320
    +5,675
    If you are going PAYG and going to register for a few (and I do strongly recommend it) then you should always look for services which allow you to create your own Dial-Up settings. Those which do an automatic install often
    1: set themselves as the default and make it problematic to undo therefore making it difficult to swap and change at will (which is the benefit of having a PAYG service)
    2: mess up your browser by branding it with their own logos etc.
    On-line registration varies between suppliers. Some won't let you proceed without an auto set up; some do (but place the instructions behind a tiny link buried deep into the web page etc), and some just produce a page with all the necessary details, letting you create the setting for yourself. I recommend you choose suppliers in the last 2 categories and do it yourself in all cases. Any that force an auto setup - just abandon it.
