Which is the better one?
Discussion in 'AV Receivers & Amplifiers' started by ][Uzzy][, Sep 6, 2004.
  1. ][Uzzy][
    ][Uzzy][
    Aug 30, 2004
    94
    I just wanted to ask which one is better out of the two.
    The Sony STRDB1080
    or
    Pioneer VSXD714
    Im hoping to get the VSXD714 but just want to see which one is better, because a friend of mine has the sony one and he claims his is better, so i came here and wanted to ask you guys.
    Much appreciated.
  2. ][Uzzy][
    ][Uzzy][
    Aug 30, 2004
    94
    BUMP. I would really like to know.
  3. ][Uzzy][
    ][Uzzy][
    Aug 30, 2004
    94
    Surely someone must be able to answer?
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,559
    4
    Aldershot, Hampshire
    +304
    With most things audio it's all subjective because what you like may not necessarily be what your friend likes. The only real way to find which is better is to listen to both set ups a decide which sounds best to YOUR ear. You can look at specs all day but they still do not tell you how a product sounds. The trick is to find a product that has all the functions you require and sounds the best to your ear for the amount of money your prepared to pay. It's often beneficial get get feedback on peoples thoughts on specific products to create a short list to audition but the decision on what sounds best is ultimatley yours. :zonked:
