which is the best - 32PD3000 or 32PD5200?
Discussion in 'Plasma TVs' started by chris210972, Jul 25, 2004.
  1. chris210972
    chris210972
    Apr 23, 2004
    382
    16
    can anyone tell me what the differences are between these too hitachi plasma displays and also which is the better of the too.
    thanks
  2. junpit
    junpit
    If the differences are the same as between the 42Pd3000 and 42PD5200. The 5200 does not come with a tuner box but has everything built into the TV. The 3000 comes with a seperate tuner and hence easier to wall mpunt wrt number of wires. The 5200 is much newer however and comes with better support for HD progressive scan resolutions like 1080i.
