Which is the best 26" tv you can buy
Discussion in 'What Is The Best TV For You?' started by Darthvador, May 30, 2008.
  1. Darthvador
    Darthvador
    Jan 25, 2005
    58
    paignton
    :)which / what is the best 26" lcd tv currently on the market
    it is for a bedroom:)
  2. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Panasonic one at around £500, or the Sony 26T3000
  3. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    There are only very few 26" models with quality LCD panel. So beaware
    Also, Amazon has the Sony KDL-26T3000 for £400
  4. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    I agree about the 26T3000 its the best
  5. golly99
    golly99
    Mar 5, 2006
    493
    28
    +34
    Got to be the Panasonic LXD70 for me, i looked at a lot of televisions, including Sony's, Samsungs, the Panasonic was miles sharper and better quality than the rest.
    Been knocked out with the picture so far, excellent watching the footie and motion as well.
    If you buy instore here, you get the Panasonic 5yr warranty too!
    http://www.soundandvisiononline.com/moreinfo/index.asp?product_id=12709
  6. flyingscotno1
    flyingscotno1
    Apr 4, 2007
    71
    +6
    Sadly not anymore- seems it was an error!:mad:
  7. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    It only went up by £30
  8. flyingscotno1
    flyingscotno1
    Apr 4, 2007
    71
    +6
    Yeah, but they reduced from £425, to £399 then up to £429. Mind you £30 these days is a trip to the shops!
  9. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  10. jeti
    jeti
    I'm also looking at a 26". I've found the KDL26T3000U available from PRC for £395 including 5 year warranty (instore only). They are based in Ilford, Essex.
    I do have a question: is the KDL26T3000U the same as the KDL26T3000? Are there any other variations I should be aware of (pros & cons)?
    I'm getting the 26" as a stop-gap until I buy a nice big beast later this year/early next year (I have no TV atm). After which, the 26" will be used as a second tv/pc monitor (hence the reason I'm not really looking for a 32"). Are there better options at around this price based on my requriements?
    Thanks.
  11. matt8594
    matt8594
    Jun 2, 2008
    4
  12. Darthvador
    Darthvador
    Jan 25, 2005
    58
    paignton
    :clap:Thanks il get one of those then. :thumbsup:
  13. mrmicp
    mrmicp
    Jul 31, 2007
    398
    +20
    Totally agree with the above :smashin: There isn't a better 26inch LCD on the market for SD & HD!!
  14. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    U simply means UK model
  15. jeti
    jeti
    Brilliant - thanks. :)
  16. jeti
    jeti
    I have a related question about manufacturers' warranties and whether they're worth the money (not sure if there's a better place to post this question, so I've put it here).
    If I'm going to have a problem with an LCD, isn't it most likely to occur within the first 12 months, meaning the extended warranties aren't really worth it? Or do problems also arise further down the track?
    Just trying to determine the value of these and if they're worthwhile purchasing.
    Comments/experiences?
    Thanks.
  17. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Buy from John Lewis and get a 5 year guarantee as standard (some manufacturers and retailers are also offering these but often for instore purchases only)
  18. flyingscotno1
    flyingscotno1
    Apr 4, 2007
    71
    +6
    JL can be expensive however, and doesn't have the biggest range.
    No T3000 for example.
  19. megaminx
    megaminx
    John Lewis are always very helpful too
  20. pwood
    pwood
    Dec 6, 2003
    2,582
    Central Scotland
    +170
    As mine is for the bedroom I dont want to spend too much but I want the best:rolleyes: On viewing TV's in Currys etc and having a go with the picture settings with the remote the 26" Samsung seems very good especially regards viewing angle from below. Anyone care to comment on this set. Beyondtelevision have it for £333
  21. pwood
    pwood
    Dec 6, 2003
    2,582
    Central Scotland
    +170
    Seems prices are coming down for this TV. Is there a new model range imminent?
  22. matt8594
    matt8594
    Jun 2, 2008
    4
    Having just bought a T3000 I've now discovered that there is a panasonic that can display 1080p for only slightly more, I've got a PS3 so have i made a mistake or is 1080p barely noticeable on a 26" screen?
  23. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  24. matt8594
    matt8594
    Jun 2, 2008
    4
    Really? I think there is a panasonic that displays 1080p for about 100 more, perhaps not that model though. Also does anyone know whether when watching blu ray on a PS3 it would be better to view in 720p or 1080i?
  25. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  26. marctwo
    marctwo
    Mar 14, 2007
    128
    +9
  27. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    Does it matter?
  28. marctwo
    marctwo
    Mar 14, 2007
    128
    +9
    It does if you are after a 1080p screen.
  29. matt8594
    matt8594
    Jun 2, 2008
    4
    Does 1080p actually matter on a 26" screen though? Can you actually see a difference?
    Only because if so I'm thinking of returning my T3000 and getting the panasonic instead.
  30. simonali
    simonali
    Jul 5, 2004
    61
    If you're talking about displaying 1080 lines then it wouldn't display 1080i either would it? That TV will, however, happily accept a 1080p signal, although I have heard that you get no sound with 24fps, which is a bit weird.
    Has anyone heard anything about this model...?
    http://www.digitalconnexions.com/moreinfo.php?id=853
    ...or are the advertisers merely speculating that it might be released?
    They also have a 19" Panny Viera on there and state a September release. No info is found on either model on googling the model numbers!
