which is faster, eSata or usb 3.0?
Monkeyman1
hiya, not sure if this is the correct section but im a bit lost lol. i have a external harddrive currently connected with usb 2.0. im getting a new laptop soon with usb 3.0 but have been reading about esata, being a complete novice can i use esata with my external hard drive? and even if i could would it be faster then usb 3?
cheers :)
EndlessWaves
To transfer to and from a drive connected internally via SATA then I'd imagine eSATA is going to be faster than USB 3 in almost all circumstances.
However, both of them are currently fast enough that it's the hard drive that's the limiting factor and not the connection.
You won't be able to use an existing USB 2 hard drive with USB 3, the usb connection will still work but it'll run at USB 2 speeds, and you can only use it with eSATA if it's got an eSATA port on it.
MarkE19
eSATA has a theoretical transfer speed of 3Gbit/s
USB3.0 has a theoretical transfer speed of 5Gbit/s
However as already stated the actual HDD will not work anywhere near these speeds - actual read from the platter to cache will be around 70MB/s for a 7200rpm HDD.
all speeds found in the following links:
SATA II
USB3.0
HDD
Mark.
