gazor
hi all, when setting speaker levels via arcam prossesor using spl meter,setting levels correctly, then doing the same process but using a thx optimiser on a star wars disc the readings are alot different. on the thx set up, my centre channel is way to high.
so which is best? is it better to use the thx disk as its a dvd being played via arcam dv79, or use the arcam settings which may be better when watching sky?
any knowledge would be gratefull
thanks
gaz
thanks
gaz
