Which is broken, my hard disc or input 2?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Jules, Aug 8, 2004.
  1. Jules
    Jules
    Oct 11, 2000
    5,566
    134
    +1,027
    My 2nd Sky+ box, a V2, shows 'system fault' on screen when I press the record button. It also shows nothing in the Sky+ planner.
    I rang Sky, and after taliking me through the 'housekeeping' procedure (which I already knew how to do) it still didn't work.
    They want to charge me £65 for an engineer.... on your bike!!! :devil:
    I then did a forced software download which didn't work either.
    On the signal test screen, there's no signal to input 2.
    So, I switched the input 1 and 2 cables round and there's still no signal to input 2.... so I guess its not the LNB.
    That leaves 2 possible problems....
    1) input 2 on the receiver is broken
    or
    2) the hard disc is broken.
    Would a hard disc failure cause input 2 to disappear? or does it sound more like a broken input 2?
    If it'll fix it, I'd rather install a new hard disc myself than have an engineer call out.
    can anyone help please?
  2. outtathaway
    outtathaway
    Dec 2, 2003
    40
    2
    11
    huddersfield
    Had the very same problem this morning, did a forced sortware update followed by a full system restore this did the trick, hope this helps.
  3. Jules
    Jules
    Oct 11, 2000
    5,566
    134
    +1,027
    I'd already done a forced software download and a full system reset and it didn't fix it.
    I opened it up, and the HD was very, very hot... I mean so hot it was almost melting the lid!!
    I took this as a sign that it wasn't well and popped down to PC world for a replacement.
    I picked up a Samsung SP1203N (120 G) for £59, and haveb just installed it.
    It now works flawlessly ! :thumbsup:
    So, for less than the cost of an engineer call out (who'd probably then have charged me more for any replacement part), I've fixed it myself and got a much bigger hard drive in the process :clap: .
  4. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    Nice on Jules.
    I had same prob with my V1 Sky+ box a few months ago. Swapped out HD and it was fixed. Sent faulty one back to Maxtor and was replaced under Maxtor warranty. :clap:
