which is better??
Discussion in 'Desktop & Laptop Computers Forum' started by scouse, Aug 26, 2004.
  1. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    between DPL2 on an amp, CS2 on a revo or DD5.1 from and NForce2 mobo?
    I've been rummaging on avsforum looking for a complete answer to this and, understandably, there are many differing opinions... so what do you lot reckon?
    thanks :thumbsup:
  2. rob_w
    rob_w
    Does it not depend on the source material ?
    Rob
  3. BBD
    BBD
    Mar 13, 2001
    442
    Lutterworth
    +3
    Logic 7 on a Lexicon ;)
  4. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    how do you mean rob...? Surely if you played the same material through each one of the systems there would be a pecking order?
    :p :D
  5. rob_w
    rob_w
    If you're playing pro-logic encoded stuff then you're not going to be able to play back in DD 5.1.
    Isn't circle surround a pseudo surround type thing ?
    If you have the source material available in a true stereo version, pro-logic encoded version, and DD5.1 version then I'd say it would be:
    DD5.1 Best
    DPL II
    Circle surround.
    I guess the results would vary on the pure stereo version, as DPL II may be better than CS on some tracks, and vice-versa. (different algorithms)
    If you're trying to extract a 'surround' effect from pure stereo sources then I guess it's hit and miss. I'd stick to plain ol' stereo as the best option there, I have Logic7 on my processor and never use it on stereo stuff.
    Cheers,
    Rob
  6. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Nforce does real-time DD 5.1 encodeing.
  7. rob_w
    rob_w
    Hi Jeff,
    I thought it just took your 6 channel eax audio and converted it to a dd5.1 format. Does it do dolby pro logic II type stuff aswell ?
    That still would mean it depends on the source though, and my statements above still make sense to me.. (at least) ie: 6 channel source is better than 2 channel with 'pseudo' surround type effect added.
    Rob.
