Which is better; shorter DVI & longer SPDIF or vise versa?
Discussion in 'Cables & Switches' started by kasumi, Nov 7, 2004.
  1. kasumi
    kasumi
    Sep 22, 2004
    872
    wigan
    +33
    My dvd player can either sit under my projector or at front under the screen.
    This means I could have a short cable length connection for the picture (DVI) but a long coaxial 75ohm SPDIF connection to the amplifier.
    OR
    If the other way round the SPDIF can be short & the DVI cable would have to be long.
    Which is the lesser of the 2 evils? ie which suffers the most over length?
    many thanks for any input?
  2. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,468
    64
    Norfolk
    +223
    DVI cabling is intended for a few metres only- it's a particularly horrible beast, not worthy of being called a transmission line. Spit, spit.
    A decent coax cable can be run to great lengths- have a look at rswww.com and look up RF cabling.
  3. kasumi
    kasumi
    Sep 22, 2004
    872
    wigan
    +33
    yeah i've got quite a lot of spare van den hul video silver stuff 75ohm lying about so could easily do a long SPDIF.
    Think I might go that way...
