Which is better one to buy
Discussion in 'Projectors, Screens & Video Processors' started by pete18, Mar 29, 2005.
  1. pete18
    pete18
    Apr 14, 2002
    1,078
    41
    Torquay
    +3
    thinking of buying a projector I have no knowledge on this department and was looking for some advice, really looking for something that will have a good picture quailty and that It can be using in size room, and whats the largest size these can project i.e screen size
    there is one benq PE5120
    http://www.dabs.com/uk/shopbybrand/easterdeals/productView.htm?quicklinx=3n5x
    or
    sony VPL-ES2 Projector 1500 ANSI Lumens
    http://www.dabs.com/uk/Search2/Product+Details.htm?quicklinx=3FWD&searchphrase=projector
    many thanks
    Peter
  2. yoskiwoski
    yoskiwoski
    May 25, 2004
    328
    +9
    you seem to have put the same link twice
  3. pete18
    pete18
    Apr 14, 2002
    1,078
    41
    Torquay
    +3
    have put in right link silly me
  4. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    The sony has a very ppor contrast ratio 300:1 compared to the benq 2000:1 and from everything I have read you need good contrast for ht. What size screen are you hoping for?
  5. MR.COATES
    MR.COATES
    Mar 25, 2002
    148
    Scotland
    The picture on the Benq is incredible for the money and very bright too.
    Between the two it's got to be the Benq based on specs alone but obviously anyone with the Sony may be able to add more to the conversation.
  6. pete18
    pete18
    Apr 14, 2002
    1,078
    41
    Torquay
    +3
    looking to have the screen size about 36 inch and hopefully when I get my own place having it setup in the living room, so depending on the size that the the projector can do not sure what size it can go up to
    cheers from pete
  7. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    36", it's hardly worth it with a projector at the moment IMO, just get a decent tft screen.
  8. pete18
    pete18
    Apr 14, 2002
    1,078
    41
    Torquay
    +3
    what size screen could the benq go up to
    from pete
  9. yoskiwoski
    yoskiwoski
    May 25, 2004
    328
    +9
    depends on how far back go to projectorcentral.com and check out their distance/screen size calculator. you want to get at least 80inches I would say
  10. pete18
    pete18
    Apr 14, 2002
    1,078
    41
    Torquay
    +3
  11. Helicon
    Helicon
    Apr 4, 2005
    5,005
    +260
    It's a bargain.....but don't expect miracles! :)
  12. pete18
    pete18
    Apr 14, 2002
    1,078
    41
    Torquay
    +3
    Whats the contast ratio for the projector would it be quick low something like 300:1
    does anyone know a review for the proline titan
    cheers from pete
  13. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    I guess that would be ok for games, very low lumens on it though so you would really need a black room for it, and as it's for games then I don't think it would be much good for films as it would be low contrast.
  14. pete18
    pete18
    Apr 14, 2002
    1,078
    41
    Torquay
    +3
    i think its gonna be better if i wait and save for the benq, might be cheaper in a couple of months
    from pete
