Which is better for music?
Discussion in 'AV Receivers & Amplifiers' started by onefivenine, Jan 22, 2004.
  1. onefivenine
    onefivenine
    Nov 5, 2003
    3,351
    Edinburgh
    +647
    Yamaha DSPAX640SE
    or
    Pioneer VSXD812
    any thoughts welcome... thanks.
  2. kocl
    kocl
    Jan 8, 2003
    585
    PORTUGAL
    +13
    I had a yamaha and sell it because its bad for music,
    Now I own a pio ax5i now and its much better.
  3. bobbypunk
    bobbypunk
    The VSXAX range are much better with music but there's not much difference in the two you state, go have a listen.
  4. balders
    balders
    Jul 31, 2001
    449
    28
    +25
    FWIW, I bought the Denon 1804 over the Yam 640 mainly because I thought it sounded better for music, so I'd recommend listening to the Denon too.
    Balders.
  5. bobbypunk
    bobbypunk
    i'd second the 1804 being good with music
  6. graxxor
    graxxor
    I've had a Yammy 640, a Pio (can't remember which) and a Denon 1803.
    If I remember correctly, the Denon was the only one that I considered really listenable with my favourite chunes.
    Cheers.
  7. graxxor
    graxxor
    Cheers.
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,499
    Edinburgh
    +1,236
    You could buy a budget AV Receiver that has Pre-Outs and buy a dedicated stereo amp too, then run the Pre-Outs for the front left and right channels to the stereo amp. For CD playback hook the cd player directly to the stereo amp. This combination will give you the best of both worlds.
  9. perrdl
    perrdl
    Jul 29, 2002
    357
    19
    Worcester
    Hi-Fi Choice have an article this month (March) which sees the £250 Sony STR-DB790 wipe the floor with a Creek and Roskan Kandy stereo amp.
    They also claim it is better than the much more expensive, Pioneer AX3 and Denon 2803.
    All tests were conducted blind.
    I've never heard the amp though, but the test is an interesting read
