Which is better for DVD and games out of the Toshiba 36ZP46P and Panasonic TX36PD50?
Discussion in 'Televisions' started by fdxd, Jan 9, 2005.
Tags:
  1. fdxd
    fdxd
    I intend to game and watch DVD's alot on the tv i will get compared to anything else.
    Are there any progressive scan comparisons too?
  2. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Even though i changed mine .I still think that the panasonic PD range cant be bettered on dvd playback.
  3. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,607
    notts
    +151
    I am also thinking about getting a 32pd50, can anyone tell me if when using the rgb scart inputs with my xbox the position of the picture can be adjusted horizontally as it is shifted slightly to the left. My sony lets you adjust both the size and position of the rgb inputs. Also do the component inputs allow this sort of adjustment.
  4. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,607
    notts
    +151
    Anyone ?
  5. Shaddow
    Shaddow
    yes, from menu service you can change horizontal & vertical position of RGB inputs and components separately
  6. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,607
    notts
    +151
    Thanks for that, could you tell me how to get into the service menu.
  7. Shaddow
    Shaddow
  8. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,607
    notts
    +151
    That is quite worrying as the one of the main reasons for purchasing the tv would to use my xbox in 480p. Is it a big problem ?
    Anyone else out there using a pd50 with a 480p signal?
  9. Shaddow
    Shaddow
    this nigth i will try to upload some screens
  10. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,607
    notts
    +151
    Thanks shadow I would appreciate that.
  11. Shaddow
    Shaddow
    The pictures
    [​IMG]
    [​IMG]
  12. PUD the Ancient
    PUD the Ancient
    Apr 25, 2003
    1,607
    notts
    +151
    Thanks for the pics, that looks pretty nasty. I don't think it should be doing that, have you spoken to your supplier regarding this problem. Can they fix it in the service menu ?
  13. fdxd
    fdxd
    looks like a fault.
    So the panny for the non sky stuff then? I'll mostly be doing games too. Progressive scan through Xbox and Gamecube. :)
    The Toshiba is a better deal.
  14. zlatan-italian
    zlatan-italian
    Nov 4, 2004
    36
    Hi I'm italian, have you a xbox modded for to play in progressive scan or you use simply the deinterlacer of tv pd50?
    Thank you.
    I would like to buy the pd50, or Jvc and toshiba, but i don't know what to chose.
