Which is best S-VIDEO or Scart
Discussion in 'Home Cinema Buying & Building' started by Smokeycat, Nov 26, 2004.
  1. Smokeycat
    Smokeycat
    Nov 25, 2004
    64
    +4
    :confused: :confused: I am abit confused about which is best.
    Some say use scart from Sky+ to amp/receiver others say use S-Video + optical (for sound)
    Which is the best option/quality?
    I have a Denon DHT-500SD by the way.
  2. Brewerp
    Brewerp
    I've never tried it with SKY+ but in general RGB Scart is superior to S-Video.
  3. blithe502
    blithe502
    Get a good quality RGB scart cable, much better.
  4. Smokeycat
    Smokeycat
    Nov 25, 2004
    64
    +4
    Any Idea which is the best RGB scart cable (less than £50)?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  6. Phill1978
    Phill1978
    Oct 15, 2004
    2,045
    48
    +84
    actually i found S-Video to be really good. The worst thing about poor connectors is the crosshatching you get over details and the ghosting + faded colour. but s-video doesnt have any of those apart from faded colour which is where a good quality lead can come in. Ive found most scarts from £20-£100 to be very simular in performance ((not audio though as that can be miles better with a decent scart))
    i accept RGB is better in general. But how many sets have no option to increase sharpness ??!!!! sooo anoying. it would be fine if all TV`s were perfectly focused and had exellent geometery but most TV`s ive used havent and seem to handle the scart connection poorley with an image with solid colours but slightly lacking in detail as you cannot alter this when in RGB mode. the TV`s fault though.
  7. Smokeycat
    Smokeycat
    Nov 25, 2004
    64
    +4
    So I need to get RBG only scart lead plus optical lead for sound.
    What happens if I use a normal fully wired scart plus optical lead,
    will the sound go through the optical lead or will it default to using the scart for sound?
