Which is best pro logic 1,2 or neo6
Discussion in 'AV Receivers & Amplifiers' started by ALIEN1X, Jan 22, 2008.
  1. ALIEN1X
    ALIEN1X
    Jan 7, 2006
    487
    +19
    which is the best decoding from stereo source Dolby pro logic 1,2 etc or Neo6?
    What are the pros and cons between them?
    If an AV amp has no Neo6, can this be installed?
    Regards
    Alien1x
  2. davepuma
    davepuma
    Jun 24, 2004
    17,536
    +3,506
    Only your ears can tell you. In theory DTS:Neo6 has a higher bitrate and should be better. If an amp doesn't have a particular decoder it cannot be added later as the decoding is done by a chip and isn't firmware upgradable unless someone can tell you different. As an amp deals with audio, the basic specs are pretty much set in stone unlike players.
