which is best at playing multi region DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by cejsmith, Jul 18, 2005.
  1. cejsmith
    cejsmith
    Apr 22, 2005
    143
    16
    I currently have a XS34, that seems to have a problem with playing non region 2 DVD's. I'm looking to get another recorder any suggesting?
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    None of the recorders from the main manufacters are multi-region out of the box. You have to get one which is modified to be multi-region. The XS34 can be bought as multi-region... I believe there are also companies which will modify it for you.
    Mark
  3. cejsmith
    cejsmith
    Apr 22, 2005
    143
    16
    sorry I should have said my XS34 it is meant to be a multi region machine. But I'm told that even thought it's meant to be multiregion there are certain thing it wont play!!!!
    So the question is are any of the recorders true multiregion?
  4. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    No machines are TRUE multiregion because they are not allowed to be.
    Some have their region coding switched off, some can be switched off, some can be modified with software and some with hardware.
    Some won't play RCE titles when modded.
    What you need is a good quality supplier and a good mod.
    I get all my machines from "multiregionmagic," and have never had a disc that cannot play.
  5. cejsmith
    cejsmith
    Apr 22, 2005
    143
    16
    Mines from RGB direct.
