Which Interconnects?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by nobby, Dec 26, 2002.
  1. nobby
    nobby
    Dec 28, 2001
    441
    wee Norn Iron
    +27
    Hi guys
    i was wondering if i could get some advice. for an xmas present i got an arcam diva cd72 to take the load of my toshiba sd900e dvd player acting as a cd player too.
    i think the player (arcam) is fantastic but i think i need to improve my interconnects. i own the following equipment
    arcam cd-72
    yamaha ax1 amplifier
    mission 782 floorstanders
    i would like to know what the best cable would be for this setup, i'm thinkin of the qed silver spiral ... i dunno ...???
    also i need to know due to thisamo being an av amp should i maybe consider an optical / coaxial connection? if so what should i get?
    Would this be a better signal, I have noticed since running dvd audio via analogue the results are fantastic
    your advice would e much appreciated
    cheers
    nobby
    :blush:
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    I have an Arcam CD player / Yamaha amplifier with Mission floorstanders.
    Personally it sounds better when connected by RCA phono leads utilising CD player's DACs than connecting by digital optical / co-axial then using amplifier's DACs.
    With regard to phono to phono leads, mine is using a Chord Chameleon which at the time was suggested by Arcam, I have tried assorted Ixos and Q.E.D. s too. I can't say any of them sound better to me than ordinary £5 cables, wish I hadn't spent £60 to buy the Chord back then but there you go.
    The sound quality difference using my Arcam connected analogue rather than digital is very noticeable and much better.
    Try it out.
