which interconnects for dvda/sacd?......
Discussion in 'Blu-ray & DVD Players & Recorders' started by PapAV, Mar 28, 2003.
  1. PapAV
    PapAV
    May 10, 2002
    187
    +15
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    go for either, as long as they are a reasonable quality you should be fine...
    I use the 3 of the QED's on my DVD-3800 to AVC-10SE
    JJ
  3. jdanielp
    jdanielp
    Jun 20, 2002
    184
    22
    Edinburgh
    +3
    well, i haven't actually got round to buying a Pioneer DV656a for DVD-A and SACD yet but i got myself a cheap IXOS 6 phono to 6 phono cable from a Dixons bargain bin a while back in anticipation of my future upgrade. it is part of the IXOS gold range of cables so presumably of decent quality for multi-channel audio and will be somewhat neater than having threes sets of phono cables.
    i managed to get mine for a tenner instead of 50 quid :eek: they still have some kicking around the stores in Edinburgh i think, although the remaining ones are only 50% off instead. the same deal was on when i bought mine but for some reason they had a couple at a tenner each as well so i got one of those ones! :D
  4. vee_cee
    vee_cee
    I've got this ixos cable installed between my 757ai and 1011 amp for sacd and dvd-a duties ......a very neat solution to the cable spagetti you get on the back of av amps. Got mine from Hifibitz.
    VC
