Which interconnects for DVD-A / SACD?......
Discussion in 'Hi-Fi Stereo Systems & Separates' started by PapAV, Mar 28, 2003.
  1. PapAV
    PapAV
    May 10, 2002
    187
    +15
  2. nathan_silly
    nathan_silly
    You'll need three pairs, so I would look around for £20 pair (£60 set) max really.
    btw, I would replace that Sony amp that's driving the subwoofer...
  3. PapAV
    PapAV
    May 10, 2002
    187
    +15
    OK I've got this sub (detailed specs);
    SB-1 Specifaction Sheet from JBL.com
    I've currently got one of the two sub pre-outs from my Sony 940 5.1 amp going to another sony amp (TAFE230) powering the sub. It sounds pucka !
    The sub seems to have some serious power handlnig (300W) so I was wondering what I could do to upgrade the amplification, but I've just though that as I'm using a stereo amplifier I'm probably pumping 2 x55W into it bu it's an 8 ohm amp and a 4 ohm sub.
    I guess what i need is a 150W x 2 4ohm stereo amp?
    Something like this (160quid).... just what i'm after?
    fit's lovely under the sofa though :clap:
  4. nathan_silly
    nathan_silly
    Can you use a stereo poweramp to drive the subwoofer- the sub has 2 channel input?- most subs are powered with one channel. Is yours different?
    I would go for that £235 amp.
    btw I noticed it's got 4 drivers, what size drivers are they?
  5. PapAV
    PapAV
    May 10, 2002
    187
    +15
    4x 5.25" cones.
    It's a stereo sub (weird I know)
    I think it should be OK?
  6. nathan_silly
    nathan_silly
    I wonder if the rated input of 300W (in the PDF file) is total for both channels, or per channel?
    It won't harm using a higher powered amp, it just means it'll sound better at louder volumes.
  7. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    I bought 3 pairs of JVC cables from Dixons for £9 each.
    I think that's the first time I've ever said bought and Dixons in the same sentence.
    Seriously though, check them out. They are very similar to the QED cable I paid £20 for. They are the same screw metal cover design.
