Which Input
Discussion in 'Projectors, Screens & Video Processors' started by smithgt, Jul 2, 2005.
  1. smithgt
    smithgt
    Oct 16, 2004
    9
    I'm considering purchasing an InFocus SP5000.
    Would I be correct in thinking that
    DVI will provide the best quality input followed by Component, then VGA and finally SVHS?
    Im looking at either using Windows MCE2005 as the primary source or getting a high quality DVD player with Component outs.
    Any help would be much appreciated.
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,418
    Surrey. UK.
    +2,083
    Probably DVI, VGA (which is progressive and can be scaled by the PC to the native res of the pj), then component (interlaced or progressive at 480 or 576), then s-video and finaly composite.
    Using a PC with Radeon graphics card like a 9600 (or better) via DVI or VGA will give a far better image than a standalone player, unless it's something like the Pioneer 868 using DVI and scaled to mathc the pj.
    Gary.
  3. smithgt
    smithgt
    Oct 16, 2004
    9
    I've got a G Force FX 5200 128mb with Dual VGA as my MCE 2005 box - is that going to be up to the job. I was going to install Power Strip to see if I can suppoer 1280x720 directly.
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,418
    Surrey. UK.
    +2,083
    I'm not that familiar weith GeForce cards, as I've only really uded Radeons in recent years. You've nothing to lose by trying it though.
    1280 x 720 should be a standard resolution (it is with Radeons anyway), so you may not need Powerstrip.
    Gary.
