Which input cards for TH37PW7
Discussion in 'Plasma TVs Forum' started by stryda, May 20, 2005.
  1. stryda
    stryda
    Im considering purchasing the Richer Sounds Th-37PW7 deal, but swapping out the tv tuner box for 2 input cards.
    So i will end up with the TH37PW7 display and the SCHT27R home cinema combo.
    I will need to connect my Telewest cable box and the DVD player that comes with the deal which has scart and RGB outputs.
    What are the two best cards to go for?
    2 scart?, 1 scart & 1 RGB? or is another combination better?
    Thanks in advance
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    you should find that component RGB will be better for your dvd player than scart and you should also find that a scart to vga converter (JS Technology) will be money better spent as opposed to a scart board for the cable box.
