Which in-wall Speakers ??
Discussion in 'Home Cinema Speakers' started by Corazonis, Aug 24, 2003.
  1. Corazonis
    Corazonis
    I have been looking at the KEF Ci Reference range of in-wall speakers. I really want to house these (like the plasmas) flush with a stud wall i'm building.
    Any ideas as to what other brands are good for these type of in-wall installation ?? Are the KEF speakers overkill for a normal living room type situation ?
    Corazonis
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,794
    87
    Newcastle
    +116
    If u do a search on this site this is a fair amount of info re inwall speakers
  3. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    It much depends on the overall level of your system and what level you expect to go to. Other than Kef, Polk Audio, B&W and M&K are all worth a look on differeing budgets.
