Which Home Cinema System (narrowed down to two)
Discussion in 'Home Cinema Buying & Building' started by ruddles, Dec 2, 2003.
  1. ruddles
    ruddles
    My Brother has just decided he wants to get an all in one home cinema for his fairly small size bedroom his only real concern is that it has dts sound/decoders and that its silver. He has looked online and narrowed it down to the following systems as they are in his Price range (up to £250) and must be able to deliver by xmas.
    * Pioneer DCS313
    * Panasonic SCHT500
    http://www.techtronics.com/uk/shop/50-pioneer-dcs-313-multi-region-dvd-player.html
    http://www.techtronics.com/uk/shop/50-panasonic-sc-ht500-multi-region-dvd-player.html?refid=kelkoo
    So Basically whats best and where would be the cheapest place to buy online or does anyone know of a better system within this price range. Any help would be much appreciated
    Ruddles
    :blush:
  2. ruddles
    ruddles
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  4. ruddles
    ruddles
    hornydragon thanks for the link.
    on the Techtronics website it says extra features added by Techtronics...
    Regions 1-6
    Region Select Auto
    VCR Mode No
    RCE Yes1
    And the one at amazon says Multi-region but would it automatic region select? like the one at Techtronics? + amazon don't list dts decoders on their website
    I think I'm just making this sound more confusing?
    thanks.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    If panny says DTS then its DTS The MR mod will most likely be the same, I would buy from amazon not techtronics, have a search and see what you think mate
  6. ruddles
    ruddles
    hornydragon
    Thanks for your help just about to order from amazon hope it arrives by xmas
    cheers.
