Which HMDI Cable Male or Female?
Discussion in 'LCD & LED LCD TVs Forum' started by hamd01, Jun 16, 2005.
Tags:
  1. hamd01
    hamd01
    Mar 21, 2005
    963
    46
    Cumbria
    +145
    Ive purchased the Sammy 32" with the HD850 DVD Player. Im going to need a 5Meter HDMI lead, which are comming in around £15 on eBay.
    What do I need, male - male or male - female.....or erm female - female?
    Why is everything SOO complicated!
    :lease:
  2. matt_p
    matt_p
    Apr 7, 2005
    851
    28
    Nottingham
    +38
    male - male
  3. flash!
    flash!
    Feb 24, 2005
    34
    Just looking for a HDMI cable myself at the moment. Found some for not much money (£15-£20) and others for stupid money (£100+) :eek:
    Is there much noticable difference?
  4. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    According to a UK manufacturer of DVI and HDMI cables that was about to get a few £££ from my credit card, if you are buying a short cable (2-3m etc), you really are not going to see any difference. Just make sure your cable and the kit you are connecting to is HDMI certified as they are tested to a set standard. I was just about to buy a HDMI->DVI-D cable from them to replace the one that I bought off eBay a year back. This advice nearly saved me £££, but I spent it on upgraded analogue interconnect instead.
    -Ian
  5. flash!
    flash!
    Feb 24, 2005
    34
    Thanks for the quick reply. :thumbsup:
