Which HDTV?
Discussion in 'LCD & LED LCD TVs Forum' started by stuartsmfc, May 2, 2007.
Tags:
  1. stuartsmfc
    stuartsmfc
    Hi everyone need some help!
    Don't know much about tv's. I am looking for a 26' HD Ready TV to use for my ps3. Can anyone recommend any? Or are there any brands that I should or should't buy? Not too bothered about the price.
    Would appreciate it if someone could help
    Thanks, Stuart:thumbsup:
  2. neeshman
    neeshman
    mate, most people aren't gonna reply to that msg, its a bit vague - we need a bit more info about how much you wanna spend. read around the forums for a bit more info - but as a starter, search the new samsung 26ler78, or the more expensive panasonic ldx70. hope that helps a bit.
  3. sauluk
    sauluk
    Jan 18, 2007
    1,004
    38
    +23
    Its pretty simple once you narrow it down (saying that ive been looking for the best of a year!) are you looking for brand name? If so go for Samsung 26" R88/7, they tend to be the best for Xbox360 so must be pretty similar with PS3. Thats the TV im going for so thats my suggestion.
    Here it is from Empire Direct, think im going to go with them because for £20 you can have a 3year guarantee: http://www.empiredirect.co.uk/content/products/details/index~modelcode~SAM-LE26R87BDX.htm
