Which HDTV
Discussion in 'Xbox Forums' started by Rhydem, Jan 2, 2007.
  1. Rhydem
    Rhydem
    Aug 9, 2006
    1,619
    48
    +39
    Im sorry im sure this would have been asked definantly but i need help.
    Im looking at buying a HDTV at around the 300-600 mark
    If you guys could guide me to a few i could take a look at.
    Also i saw the graphics of Fifa 2007 on the internet on www.gametrailers.com
    and it looked fantastic.
    I went to PC World and they had FIfa 2007 on display to play on a HDTV and it looked all fuzzy.
    Which is why i really need help
    Cheers in advance
  2. rela
    rela
  3. Tezcatlipoca
    Tezcatlipoca
    Jan 2, 2007
    139
    +9
    I recently (received it last Weds :) ) bought a 26" Samsung LE26R73BDX HD Ready LCD (with built-in Freeview) from Currys.
    It's apparently the Dixons/Currys/PCWorld "exclusive" version of the LE26R74BDX you'd see everywhere else like Hughes, Dabs, etc (only difference is the colour of a bit at the bottom of the case, under the power button).
    It's gorgeous :D
    It's had (or at least the slightly cosmetically different R74 has had) 5/5 reviews in What HiFi, Stuff (or maybe T3?), Computer Shopper, and other places, & I've seen various glowing user reviews of it at an XBox forum I'm a regular at.
    Anyway. I love it.
    My 360 is currently connected to it via Component, & looks awesome (especially Gears of War!). DVDs look great, played via the 360 using progressive scan (the 360 will only upscale normal DVDs is you use VGA - if you use Component you have to settle for PAL progressive scan).
    Integrated Freeview is excellent, & Sky Digital via RGB SCART is very good.
    I'm currently trying to buy an HD-DVD drive for my 360, if they ever get back in stock.
    The normal list price (without using discount codes or whatever) for the LE26R73BDX at Currys/Dixons/PCWorld is £579.99. Amazon has the LE26R74BDX for £499 IIRC, & I think Dabs now also have the R74 for £499 (sale price).
  4. Br1an_g
    Br1an_g
    Dec 22, 2005
    726
    28
    Glasgow
    +31
