Which HDMI to DVI Cable ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by kumamoto, Mar 9, 2005.
  1. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    I just purchased the marantz dv 9500 which has a dvi output and want to connect this to my philips plasma which has DVI inputs.
    Can you please recomended a high quality HDMI - DVI cables.
    Any imput will be greatly appreciated.
    I have some cables on ebay that go for about 20 quid. Are these any good.Also i don't want to pay lots of money and get no perfomance advantage.
    Please help !!!! :thumbsup: :thumbsup:
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    What length were those for £20. A 2m good quality from Molex costs just over £20, 5m is around £35. IMX these are fine.
    In comparison a 2m BetterCables costs £66. ;)
  3. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    about 3 metres
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    No idea of which brand? That seems a reasonable price to pay for a medium quality cable I think.
  5. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    not branded.
    Any ideas of a high end cable manufacturer ??
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,933
    The Borders
    +3,575
    kumamato
    You say both bits of kit have DVI connectors yet you ask for a DVI to HDMI cable?
    If your player applies HDCP to its Digital Output (always with HDMI and sometimes with DVI) then you need to ensure your Display is also HDCP compliant.
    You don't need a 'High End' cable you need a well manufactured cable - as KraGorn says a relatively low cost Molex 3m DVI cable will do the job for under £30.00.
    A 3m BetterCables DVI cable will be nearer £80.00 and our tests have shown the heavier conductors and less 'resistant' cable used by BetterCables degrade the signal less than the Molex cables - see http://www.bettercables.com/2me6febecadi.html
    There are plenty of even costlier DVI and HDMI cables - though I've yet to see any that warrant the extra cost.
    Always worth trying out the various options before you purchase.
    Best regards
    Joe
  7. deanym
    deanym
    May 29, 2004
    1,833
    +143
    I can only back up what Joe says, he allowed me to demo some DVI/HDMI cables and there was a performance gain from bettercables against Molex, but anything more expensive (up to three times more) there was no gain over the 2m I was testing.
    A bettercables unit would give you as close to high end as you'll get and you're not paying crazy money.
  8. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    thanks for all your response guys, much appreciated.
    I have a philips lcd tv which has a dvi input which is HDCP compatible.
    The marantz on the other side has HDMI only. So i suppose i will need a HDMI to DVI cable. Is this correct ??
    I will try a few sensible money cables and settle for the cable that gives me the best value/ best pictures.
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,933
    The Borders
    +3,575
    kumamoto
    HDMI2DVI sounds like it will be ideal for your set up.
    You may have to 'tell' your Player to switch on its HDMI Output - its not always an automatic connection when its DVI at the other end of the cable.
    Best regards
    Joe
  10. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    thanks joe
  11. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    I picked up a Supra HDMI 2 DVI cable to use from my Denon 3910 to my Samsung LCD (using the HDMI end on the Denon). Worked like a charm and set me back about £45.
    Ironically @ the time Sevenoaks and another specialist outlet said they didn't exist. Sevenoaks said it could get one made up specially (for £100) and the other shop said I'd never get it and I'd have to get an HDMI-HDMI and an adaptor. Pointed out that they do exist and that Supra and Monster sell them, only to be told "We don't sell them". So basically with that store, if they don't stock certain manufacturers products, well they clearly don't exist.
    Talk about snobby attitude eh ?
    Anyway can't knock the Supra - although pale blue cable isn't the most attractive ;)
  12. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    WHERE did you buy the supra from ??
  13. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
