which Hdmi cables? And how many i need?
Discussion in 'Cables & Switches' started by johnboy373, Sep 11, 2007.
  1. johnboy373
    johnboy373
    HI ive attached a diagram to make it easier to explain. I'm about to start buying the finishing touches for my AV set-up. My AV stand is going to be around 2-3 metres from my tv.
    Just need some advice as to what i need. Also should i use wall HDMI sockets or try and connect them directly.
    Cheers in advance
    john
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,759
    The Borders
    +3,523
    Hello johnboy373
    Probably easier if you list out your kit (Manufacturer and Model number) - the drawing makes it a bit tricky to read your product codes.
    Joe
  3. johnboy373
    johnboy373
    Ok here we go.
    TV 42" LC-42XD1EA
    AMP SONY STR-DA1200ES
    SPEAKERS MONITOR AUDIO BR5,BR-FX,BR-LCR,BRW-10.
    PS3
    SKY HD
