Which HDD for XBox upgrade
Discussion in 'Xbox Forums' started by stormjai, Jun 15, 2005.
  1. stormjai
    stormjai
    Nov 15, 2003
    331
    Bromley
    +3
    I want to upgrade a crystal XBox.
    Are there any "recommended" makes of HDD for XBox?
    Any particular ( "cheap but reliable" ) places to get these?
    thinking of 200-240GB drives!!
    Thanks for any suggestions. :thumbsup:
    Jai
  2. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,369
    I stuck a MAXTOR PLUS9 6Y120L0 120GB 7200RPM 2MB UDMA133 in mine and it works a treat - cost £43 back last October so you can probably get it cheaper now. I'm sure you can probably get the same make in 200gb + as well.
  3. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    Have a look at this list.
    Also, make sure your replacement drive is lockable. I replaced my original drive with Western Digital 80Gb model and have just upgraded that to a 160Gb Seagate. Both were lockable and have performed brilliantly.
  4. Goose74
    Goose74
    Sep 24, 2002
    827
    Romsey
    +12
    sorry for my ignorance but what does lockable mean? (I noticed that option in EvoX)
  5. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    +8,369
    It's just a security feature that prevents the user from viewing the contents of the original hard drive. Live checks to make sure that your drive is locked so if you go on live you must have it locked.
  6. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    And if you don't, you get banned. Just as if you have used Live before you upgrade your hard drive, you will get banned after you do the upgrade.
  7. Goose74
    Goose74
    Sep 24, 2002
    827
    Romsey
    +12
    cheers guys that clears it up
