which graphics card
Discussion in 'Desktop & Laptop Computers Forum' started by wynouk, Jul 25, 2002.
  1. wynouk
    wynouk
    I've got a panasonis PT AE100 and i need a twin monitor output graphics card, could anyone give me some advise on a good value for money 1 to buy, the card will also be used for light gaming as well.
    thanks
  2. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    The Radeon 7500 would probably do well, but if you wanted a bit more power then the 8500 would be better.
    We should hopefully see some pretty dramatic price falls soon, when the 9000's/9700's start to come through.
  3. wynouk
    wynouk
    Does the rad 7500 and 8500 both support plugging 2 CRT monitors in at the same time or does it have to be 1 CRT and 1 DVI monitor as i would like to plug 2 - 15 pin rgb plugs in, 1 for my CRT and 1 for my panny.
    I've saw rad 7500 and 8500's sold on ebay and i was wondering do they normally come with some type of adaptor to change from DVI to CRT and if they don't where could i buy 1 and how much would i expect to pay.
    Thanks.
  4. MerMan
    MerMan
    Mar 31, 2002
    146
    16
    Wynouk
    I have a Radeon 8500 and it comes with a DVI to VGA adapter.
    Regards
  5. triplebj
    triplebj
    The 7500 has one VGA and one DVI output and comes with a DVI-to-VGA adapter. I have mine hooked up to my LCD monitor and projector - works like a charm once you find the check box for "Theatre Mode" ;-)
    BJ
