which graphics card?
Discussion in 'PC Gaming & Rigs' started by bumble, Jun 23, 2005.
  1. bumble
    bumble
    which brand of 6600gt is best? what would be the ati equivalent? running pent 4 2.4ghz 1gb 2100 ram,currently running ati 9600xt 256mb and have been told 6600gt much better? any thoughts? thanx in advance......
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,419
    2
    In a secret location with Jennifer Lawrence
    +9,115
  3. leeboy2k3
    leeboy2k3
    Jan 20, 2004
    237
    walsall
    +6
    skip the 6600gt mate go for 6800 or gt if you can, the 6600's vid ram is bottlenecked by its 128bit bus so you have to clock em higher.
    My advice wait till autumn see what nvidia and ati release then, should drop current prices further.. plus pc gaming has all but ground to a halt.
  4. bumble
    bumble
    would my p4 be man enough to run a 6800gt? heard rumours 3ghz and over for 'high end' cards? i have looked at ati x800xt for £210 seems a good card.......any opinions?
  5. bumble
    bumble
    one more thing........ :rolleyes: my mobo is only agp 4x enabled....is it worth the upgrade to 8x,meaning i'd have to change ram as well?
  6. Solar
    Solar
    Dec 2, 2003
    2,549
    Earth
    +463
    its the mobo you need to upgrade for 8x agp not the ram and yup its worth it upgrading
    going from a 9600xt to a 6600 wont see much difference, and i bet your not even running that to its full potential, 9600xt's are 8x agp and your running it at 4x
    if you can get the x800xt for £210 then go for that. Bargain price for a top end card :smashin: after the mobo upgrade obviously
  7. bumble
    bumble
    thanx for the advice, the reason ram needs upgrading is i'm running 1gb 2100 and most mobo's i look at do not support that speed :( damn nothing ever easy.....maybe mobo and ram for now then look at cards in a month or two........call of duty 2 needs to run at best spec poss! :smashin:
